wiring harness recommendations
So, my son's 54 is gonna need to be rewired. It has years of being hacked together. What is everyone's recommendation on a wiring harness? I have seen a set up from F100 Parts that is pretty reasonable. I have also seen Painless Wiring systems that go for around $400. Just getting some input here. Thanks!
Matt Jarma
Temple, TX
Matt Jarma
Temple, TX
Matt Jarma
Temple, TX
Matt Jarma
Temple, TX
Wiring Harness
It's pretty easy to install, fits in a tight space, and has plenty of circuits for whatever you have, and whatever you want to add later.
Unless you are doing a Concourse Gold restoration, I wouldn't go back with original. I don't like the idea of the breakers or unprotected circuits. But that's just an opinion.
Received 4,135 Likes
on
Has his truck been converted to 12V neg ground? All the aftermarket universal harnesses are for 12V -gnd. If you are staying with 6V + ground.you are going to be limited to a stock replacement harness. Another vote for the EZwiring harness. Speedway motors Speedway Motors, America's Oldest Speed Shop also has a good reasonably priced harness.
dan187
05-18-2013 11:38 AM
81F100C
07-20-2012 06:55 PM
