early 99 powerstroke p1670 code. what to do now?
Old 08-02-2014, 12:51 PM
greg_8507's Avatar
greg_8507
greg_8507 is offline
Originally Posted by Pikachu
Is it that it won't crank at all with the key, or will it crank but not start and run?
Thats a good question actually. I made the assumption that it wouldn't crank at all because you stated it doesn't matter how hard you press the clutch in.
Old 08-02-2014, 01:19 PM
fordguy2236's Avatar
fordguy2236
fordguy2236 is offline
Won't do anything at all
Old 08-02-2014, 02:02 PM
fordguy2236
All I here is a click form passenger side of truck when I try to start it
Old 08-02-2014, 03:35 PM
greg_8507's Avatar
greg_8507
It's starting to sound more like a starter issue. There is a starter relay on your fuse panel. And I'm sure there's also a fuse for it. I'm trying to think off all the simple things.
Old 08-02-2014, 04:18 PM
fordguy2236
Just reaplaced the solenoid and still nothing
Old 08-02-2014, 04:44 PM
fordguy2236
i found the starter fuse, but where is the starter relay
Old 08-02-2014, 05:01 PM
greg_8507's Avatar
greg_8507
I tried to pull up the owners manual online, but it seems that part of the Ford website is down. I don't know when it changed but your fuse panel is different from mine so I can't look it up and tell you.
Old 08-02-2014, 05:02 PM
greg_8507's Avatar
greg_8507
I want to say it is next to your air box
Old 08-02-2014, 05:41 PM
greg_8507's Avatar
greg_8507
Correction. The 99 owners manual is unavailable. I was able to pull up the 2000. I know where are differences between the e99 and 2000, but I can't speak intelligently about what they are. I didn't see a starter relay for the 2000. For mine, which is an 03, it's relay 307. I do know the fuse panels changed. I think it was in 01?
Old 08-02-2014, 05:59 PM
fordguy2236
Ya mine is an e99. Could it be the starter itself? Next to the fuse box under the good there are two other black boxes. Is it one of those?
Old 08-02-2014, 06:25 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
On the right fender you'll see a relay that resembles the glow plug relay. If you jumper the two large lugs, the starter should engage. Obviously, make sure the transmission is in neutral, and the park brake is set before doing so . . .
Old 08-02-2014, 11:07 PM
fordguy2236
Ok I'll try that tomorrow. If that doesn't start the truck then would that be the starter?
  #28
Old 08-03-2014, 08:51 AM
greg_8507's Avatar
greg_8507
Usually if it is the starter it will atleast try to turn. But that doesn't mean it wont be the starter. Do you have a multimeter?
  #29
Old 08-03-2014, 09:08 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Not necessarily. But if it does turn over normally when the relay is jumpered, then the starter is eliminated as the problem.
  #30
Old 08-03-2014, 10:58 AM
Tugly's Avatar
Tugly
Tugly is offline
Slowing down a bit, if you short the two big posts on the starter relay located on the passenger fender well, does the starter crank? What is the voltage on your battery cables (not the battery posts)? This could be a simple matter of corroded or loose cables.
Quick Reply: early 99 powerstroke p1670 code. what to do now?
