460 help....
Old 07-30-2014, 08:11 PM
mudlife2172013's Avatar
mudlife2172013
mudlife2172013 is offline
460 help....
hey guys, ive got a 1993 f350 with a 460. originally it was a 2wd dually but in the last year ive converted it to a single rear wheel 4x4 mud truck, about 10 inches of lift on 37's, going to do cross over steering here soon after I get it running.
got 2003 1 tons (balljoint d60, sterling 10.5), put a c6 tranny in, I believe a np 208 transfer case but I could be wrong.
was given some front lift leaf springs when bought so its got those in the front and blocks on good condition stock springs in the rear
the 460 is stock but I wanted it carbureted so I put an aluminum torker 460 intake on and since then it wouldn't start. I just remembered the other day about that adapter price motorsports has so im going to bolt that sucker up to the original efi intake and plug the injector holes and throw the holly 600 back on and it should start, ive also got an old points dizzy that my buddie put that pertronix piece in and an msd coil that was given to me.
as far as the gas tanks go, I removed both tanks and put 1 38 gallon tank in the rear, with an external fuel pump mounted to the inside of the frame under the drivers door
my question for yall is, eventually, what kind of cam could I run with that setup? I wasn't sure if I can just run any cam because of the f3te heads its got on it. the 460 is still in good shape but I want more low end grunt, pulling houses down kinda power lol well eventually
any and all advice would be greatly appreciated! thanks guys!
william16339
05-27-2016 02:37 PM
mike240zt
10-25-2009 04:34 PM
77f150got_sand
13
08-26-2007 03:45 PM
first time 4x4
07-02-2003 08:24 AM
alabamabuddog
06-04-2003 08:18 PM
Quick Reply: 460 help....
