what radiator
Old 07-29-2014, 08:57 PM
69issofine's Avatar
69issofine
69issofine is offline
what radiator
i have a 69 f-250 with a 300 inline. do i use the radiator out of the 69 or get one out of a 91? the 69 is a downflow with the hoses at the wrong spot and the 91 is a cross flow that mounts different.
Old 08-01-2014, 09:32 AM
trozei's Avatar
trozei
trozei is offline
How could the radiator built for your truck possibly have the hoses in the wrong spot?
Old 09-04-2014, 11:18 AM
69issofine's Avatar
69issofine
radiator in the wrong spot
the radiator that is in the truck has one fitting on the top on the passenger side and two fittings on the bottom, it was hooked up to go straight through with no cooling effect. As the two fitting on the passenger side is inline with each other it only utilizes half of the radiator,but the cross flow from a 91 the inlet and outlet are opposite of each other making the coolant flow across and out the other fitting that and an electric fan should cool it off better because right now it runs for about five minutes before it starts to overheat. The fittings on the 91 water pump, has the top fitting going towards the center,and the bottom fitting is towards the passenger side i don't know maybe my radiator is toast,I tried to run water through it it seemed to run ok. I know i need a fan shroud but i was thinking of a electric fan i have a radiator out of a 95 windstar to use as a mockup templet it only has two or three tubes broke but it should work for a template.
Guhfluh
09-21-2013 02:58 PM
SoManyFords
20
06-02-2013 09:20 AM
MintFord
01-01-2009 06:34 AM
jimhackney
04-24-2007 08:55 PM
Jack_PA
01-12-2003 10:38 PM
Quick Reply: what radiator
