High Idle Problem, 1995 EX EB 4.0L OHV
1995 EX 4.0L OHV. My idle speed in neutral has crept up > 1,100 to 1,200 RPM. With the IAC valve disconnected it slows down but not quite back to normal. Changed IAC valve.... same problem. Checked engine and air temp sensors with ohmeter back to the PCM connector and they're both within spec cold & hot. TPS sensor seems OK running at 1.1 VDC at idle. All visible vacuum lines are in good shape and connected. I tried another PCM unit
(used) and it has exactly the same symptoms. I'm getting close to a trip to the dealer but cringe at the idea.
Any help would be appreciated !!
DWB
DWB
