sisters truck
07-27-2014, 09:27 PM
on
sisters truck
92 f150 ext cab 4x4 5.0 auto..... the fuel pump runs and runs but motor will just crank and crank with no start......but occasionally the fuel pump will prime up and shut off then the motor starts and runs just fine but the next time you shut it off the pump will just run again.... it is carrying 40 psi at the rails and has a full tank of gas so my main question is there anything that would have gone bad that signals the injectors to spray? or causing the pump to run but bypassing back to the tank? this is the whole reason i stick with 79 and older there is more things i don't know about that i should.....any info is appreciated
07-27-2014, 09:57 PM
Fuel pump running all the time is an ominous sign of computer death.
07-28-2014, 06:40 PM
on
where is the computer located on this truck
on
07-28-2014, 06:44 PM
on
where is the computer located on this model? and i was wrong its a 94
07-28-2014, 06:45 PM
on
on
07-28-2014, 06:46 PM
on
07-28-2014, 06:47 PM
on
on
07-28-2014, 06:48 PM
on
07-28-2014, 07:14 PM
on
It is in the left kick panal
07-28-2014, 07:59 PM
on
had some computer difficulty sorry about multiples.....can i get a picture of what im actually looking for by any chance?
Jchristman
07-03-2018 06:26 AM
JetMech07
10-01-2011 09:10 PM
BKS72
03-20-2010 07:01 PM
tonfro
01-14-2008 05:02 PM
