94 mustang gt 5.0 throttle body
Old 07-26-2014, 08:27 PM
new7.3owner's Avatar
new7.3owner
new7.3owner is offline
I just got a 94 mustang gt 5.0 it has headers duel exhaust cold air intake and a small cam im wanting to put a bigger throttle body and a chip in it but I dont know which one would be better a 70mm or a 75mm throttle body need help please
Old 07-27-2014, 12:57 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
A larger throttle body by itself won't help much on an engine that is otherwise stock, even with a chip. Usually, the intake manifold opening was matched to the stock TB, and putting a bigger one on will leave a ridge at where it meets the manifold. But if you plan to install a new manifold as well, most of the aftermarket types have 70mm openings. I would check with the manifold you plan to get.
Old 07-27-2014, 09:39 AM
Conanski's Avatar
Conanski
Conanski is offline
A throttlebody is a complete waste of your time unless the intake(upper and lower) are also upgraded. And same goes for the chip, on this vintage motor it won't do anything you can't do for free.
Old 07-27-2014, 11:47 AM
new7.3owner
What r your thoughts on a mass air meter
Old 07-27-2014, 11:48 AM
new7.3owner
Old 07-27-2014, 04:39 PM
Conanski's Avatar
Conanski
Conanski is offline
Do the intake first buying a bigger TB for it when you do, and then if the motor is still wearing the stock heads upgrade those next. Then the motor will need larger injectors so that is when you also get a larger MAF meter.
mac_91
1978 - 1996 Big Bronco
11-28-2008 02:24 PM
drift91
11-22-2004 09:11 PM
bigbluebronco43
11-19-2004 12:06 AM
tmcgin
08-17-2002 03:57 PM
grazier1
06-29-2000 04:04 PM
Quick Reply: 94 mustang gt 5.0 throttle body
