Home Brewed 70 Short Bed Build
#61
Thanks blue04.5, After desiding to box the sides I thought it would look better to put a smooth floor in it to, so I removed the old floor and used some heavy sheet metal I had, 14 Gauge I thank. Then epoxied it then put Herculiner on it.
Thanks FILTHY, after looking at pictures of what you have done to your truck thats a real compliment.
#63
Well I got a little more done to the truck today. My son came over to the shop and we got the bed set on. Also got the shift linkage reworked, so it now shifts from the column, I still need to rework the bracket to hook the TV cable to the carb, anyway thats another days work. Here is a few pictures to show how it is looking.
#64
on
Very nice work and you've been moving right a long on this project.
One thing, I did to my replacement tailgate was add some of the bed roll on bed coating that has saved it from getting scratched up if painted. And it's easy to cover any little place if it dose scratched.
The Bad is, I have a topper as some guys call them but on the west coast of sunny California there called camper shells.
Now back to the bad is if you ever have to crawl into the bed on your hands & knees. Making knee contact on that rough bumpy surface is not something you don't want to ever have to do again. And to add to it having old boney bad bum knees to start with..
Not sure if any worse then having some aluminum diamond plate covering on the inside of the tailgate. But sure makes you remember it the next time you have to retrieve something out of the back crossing over that wonderful bumpy stuff..
Orich
Orich
#65
#66
I know where your at on your knees. Between my back and legs I find myself setting as much as I work. While my son was helping me with the bed today we talked about the pros and con of bed liner on the tail gate. I think I'll probably paint it for now, just to see how it looks since I smoothed it inside and out. I can always add it later if I decide to, but it's hard it take it off.
#67
on
So I did it myself in zolatone that lays pretty flat which was not any problem moving over it on my hands & knees. Then about 12 yrs about replaced my tailgate stripped all the yellow paint off and since I did not want buy a $50 qt of zolatone just for the inside the T-gate Thorugh I'd try some of the roll on at Walmart $8 buck.. But that day it got pretty warn fast and maybe should have waited for a cooler day buy I needed it done so went for it, it sets up faster then I thought it would.
So ended up being pretty rough on a old farts bony knees.
My doctor gave me a knee brace about 5 yrs that's a pain to have on.
And no crawling around when it's on. Can't wear it while tinkering around with the truck. Doc says I was lucky to make to my age at that time.
It was when I was a little younger then of 66.
But now being 71 with only one knee surgery, 3 back surgeries, 1 eye surgery, 1 shoulder, 3 foot surgeries. I can still drive my old 71 4wd with manual steering and bang that 5spd. I feel good like, I got another 10 yrs left~~~ I hope
Orich
#68
Now back to the bed. When I first started this build I was planning on a wood bed, but I knew if I went with wood I would never lay anything in it, so the bed liner won out. It turned out a little rougher then I wanted it to be, so I'm just hoping now it's not to hard to keep it clean and looking good. This truck want never see any heavy use (I have another truck for that) but I don't want it to become a garage queen.
#70
#71
f100today I have a picture of the outside of the tailgate handle, but I guess I need to take one of the back side. It's off the tailgate right now so I can block it for painting, so I'll take the camera to the shop and take a couple. If you have a welder they are pretty easy to make, you can see I just made to out of what I had.
#74
#75
