Clutch Pedal Problems
Old 07-25-2014, 07:43 PM
1984F2506.9's Avatar
1984F2506.9
1984F2506.9 is offline
I think my clutch is going out, when i push the clutch, shift, and let off the clutch pedal comes a little then stops and then either pops on its own or i pull it with my foot. Is it my clutches or something simpler?
Old 07-25-2014, 09:14 PM
1984F2506.9
Found the problem its my slave cylinder, anyone know how to remove it?
Old 07-25-2014, 09:23 PM
wtroger's Avatar
wtroger
wtroger is offline
If you have a lot of miles make sure the bushings in the clutch shaft aren't wore out and that the stub shaft that the master rod attaches to isn't worn badly. My master is good but the rod eye and stub shaft are worn and cause me to have lift the pedal with my toe.
Old 07-25-2014, 10:56 PM
1984F2506.9
I dont think its that when i push the clutch all the way down put the truck in gear i can drive around without letting off the clutch
Old 07-25-2014, 11:40 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
proper clutch adjustment is most important, hydraulic clutch's are not self adjusting, to much free play at lever can make the clutch drag
Old 07-26-2014, 03:57 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Make sure your firewall isn't tearing as well.
h.ubk
09-04-2019 09:11 PM
Tony G
07-15-2004 01:35 AM
turboboy
06-30-2003 08:08 PM
kenf1948
24
09-22-2002 05:25 AM
might_b_giant
10-01-2001 07:36 PM
Quick Reply: Clutch Pedal Problems
