Darn clutch
Old Sep 26, 2001 | 11:25 PM
might_b_giant's Avatar
might_b_giant
Darn clutch
Lately when i depress the clutch i get a pop which feels like It's coming from the pedal its self. Anybody got a clue as to why?
~eriC
Old Sep 27, 2001 | 07:14 AM
TallPaul's Avatar
TallPaul
Darn clutch
My '84 F150 started doing that. The pop was the noise of the rusted out firewall flexing every time I depressed the clutch. Shored it up with a piece of angle iron, but water leaks in.
Old Oct 1, 2001 | 12:06 AM
fish462's Avatar
fish462
Darn clutch
I would check the pushrod from the clutch pedal to the clutch master cylinder.
Old Oct 1, 2001 | 04:59 PM
farmtruck21's Avatar
farmtruck21
Darn clutch
I have a 95' that did the same thing. Turned out to be the plastic bushing on the starter interlock switch. Follow the shaft that the clutch pedal is hung on over to where it is above the gas pedal. The end of the clutch master cylinder rod and start switch is there. If it is that--GET IT REPLACED! I let mine go then one day I went to shift into OD, and my cluth stayed on the floor--the bushing had finally given out and the clutch master cylinder rod fell off the shaft. I was on the side of Interstate 95 w/no phone. I ended up sliding it back on and putting a zip-tie in the groove to keep it from sliding off. Good luck, hope this helps.
Old Oct 1, 2001 | 07:36 PM
Pastmaster's Avatar
Pastmaster
Darn clutch
