flexible brake line.
Old 07-28-2014, 08:37 PM
Myfreeford's Avatar
Myfreeford
Myfreeford is offline
I am installing a Hurst line lock on my 75 f250 and would like to use flexible brake line between the proportioning valve and the solenoid. I would also like to swap out the two lines between the master cylinder and proportioning valve.
Any concerns I should have with using flexible brake line. .. other than the cost?
Old 07-29-2014, 06:07 AM
JWA's Avatar
JWA
JWA is offline
Received 1,410 Likes on 1,112 Posts
IF whatever flexible line you'd use is rated for the pressure and use there should be no huge down sides. Question though--will this be an appearance thing with fancy lines or you thinking along another line?
For some reason I'm seeing external chromed braiding inside a tricked out engine bay?
Old 07-29-2014, 12:07 PM
Myfreeford's Avatar
Myfreeford
Well, not tricked out, but working on it. .
As for functionality, I like working with flexible lines rather than hard lines. Just seems easier to fit.
Old 07-29-2014, 03:06 PM
Matt@Flowmaster's Avatar
Matt@Flowmaster
Matt@Flowmaster is offline
Former Vendor
Hurst is one of our sister companies, so I can tell you with confidence that you won't have any problems using flexible brake line with your Hurst roll control. Make sure to use the appropriate diameter line and it will not only be totally functional, it should look pretty nice as well!
Old 07-30-2014, 12:10 PM
JWA's Avatar
JWA
JWA is offline
Originally Posted by Matt@Flowmaster
Hurst is one of our sister companies,....
As awesome as Hurst was and probably still is they've yet to replace the beautiful Ms Linda Vaughn as a spokes model.
The aforementioned Ms Vaughn was also of the right diameter, fully functional and looked pretty spectacular as well!
Old 07-30-2014, 02:07 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,779 Likes on 1,347 Posts
I have a local shop here that makes SS brake lines for cheap (and any other hose you can think of...they are known for their commercial hydraulic hose). I ran SS braided hose on the rear axle of my '78...all the way from the frame to the calipers. Worked great! I think I paid $40 for all of it.
Jackford
07-14-2022 06:09 AM
cjben
08-25-2015 04:56 PM
pace car
09-30-2012 04:11 PM
cbjr61
09-21-2007 05:33 PM
FLJ
02-18-2006 05:42 PM
Quick Reply: flexible brake line.
