Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tire pressure
Old 07-25-2014, 03:59 PM
claycomotrucks1991's Avatar
claycomotrucks1991
claycomotrucks1991 is offline
Tire pressure
Just got some new Michelin lattatude tour tires on 2010 Escape 235/70-16 to replace older set ,what tire pressure you guys run the dealer put 36-37 cold psi but I was running 35 psi on the old sit and got 75,000 miles out of them!
Old 07-25-2014, 06:05 PM
scott91370's Avatar
scott91370
scott91370 is offline
That's too high.
Look at the door jamb, that's what I always go with. Every set I have put on the Tribute has gone over 60k, the factory made it to 75 or 80 if I remember correctly.
Old 06-07-2015, 03:14 PM
SCUDDOG's Avatar
SCUDDOG
SCUDDOG is offline
Question What about a tad bit more?
Gents,
What about inflating to 2 lbs over the suggested/recommended tire pressure as stated on the door jamb? My 2014 Escape calls for 35 lbs... an interesting pressure because that pressure is usually what any tire shop defaults to when inflating tires.
For years and years I have been following the door jamb or in some cases glove box pressure recommendations plus 2 lbs. My theory is that it is not too much of an impact on ride stiffness and it can only help economy. Arguments can be made that it could compromise wet braking of course.
What do you guys do? A tad bit over? Follow the exact PSI? Something else?
Old 06-08-2015, 06:23 AM
jbtecnico1's Avatar
jbtecnico1
jbtecnico1 is offline
I do door jamb plus 2lbs regularly, check it every month, early morning.
Running Michelin LTX MS2 on my Exped, F150 and Escape.
The real trick is to find a gauge that you can trust.
I use a cheapo mechanical type with 0-50psi range for easier reading and dialing it in. I replace that gauge every year or so, or when the psi slider gets "sticky"...
So far so good for performance, tire wear and life span.
Old 06-08-2015, 06:53 AM
wptski's Avatar
wptski
wptski is offline
The crazy Escape Hybrid owners run 50-55psi and think it's great. That kind of pressure would beat me to death on my local roads.
Old 06-08-2015, 06:57 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Wheel bearings too
scameron7
2009 - 2014 F150
17
12-02-2012 06:45 AM
bigredtruckmi
1999 to 2016 Super Duty
10-22-2008 03:37 PM
DieselRunner
16
02-15-2008 09:51 PM
_Gadget
09-01-2004 07:49 AM
WKMOTZU
03-12-2003 09:20 AM
Quick Reply: Tire pressure
