Android Tablet and OBDII
Ok fella's, I'm exhasuted from searching and still have not found my answer. I have an Android tablet and have downloaded the free versions of Dash Command and Torch Pro. Looking to Buy a wifi OBDII device of Amazon. Both apps give a lot of information,,,,, useless to me to know 1/4 mile in a 3/4 ton truck, what I don't see in either app is EGT temps. Is there a compatible wireless obdii device and android app that will give me that temperature without having to drill and tap my block to install a hard wired sensor?
Rather than use my tablet, I bought a Scangauge II. For 150 bucks, by using the x gauge codes you an program it to monitor most of the EGT sensors. It was the least expensive way to do it without spending 1500 bucks. I tried the blue tooth dongle in the OBD II port and using apps. Just was not satisfied.
the pids for those aren't in the android apps yet..
one of our members is working on them
see
https://www.ford-trucks.com/forums/1...ed-pids-2.html
and
https://www.ford-trucks.com/forums/1...que-pro-3.html
I am working on the plugin for TorquePro so later you won't have to type them in manually,
see
and
I bought this ODBII BT adapter and it is working fine with my tablet and Torque Pro.
I should note that I bought the same adapter 3 years ago and it didn't work properly. The Torque Pro developer says the ELM327 adapters can be flakey. Not sure if I got a bad one or my phone was the culprit.
Amzdeal V1.5 ELM327 OBDII OBD2 Bluetooth Wireless Car Diagnostic Interface Scanner - Bungee Cords - Amazon.com
Im50fast
08-09-2017 08:51 AM
Tugly
16
01-14-2014 04:17 AM
