Early ICP in a late year model engine: Any benefits??
Old 07-24-2014, 06:43 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
So as long as the ECM/PCM sees .85V from the ICP it says start!
Once the truck is running if there is any fluctuation in the ICP value at an idle, the truck goes stupid/wacko. At least that is what happened to me when my ICP sensor decided to go **** up!
Does the ICP play any role during the drive cycle?
  #47
Old 07-24-2014, 07:05 PM
cheezit's Avatar
cheezit
cheezit is offline
Icp controls what the pcm is doing with the ipr.
Your issue was a bad sensor, the pcm and or the engine was unhappy with its input
  #48
cheezit's Avatar
cheezit
cheezit is offline
  #49
Old 07-24-2014, 07:10 PM
Restlesswildman
So as the ICP values go up and down as you drive the truck the PCM adjusts IPR accordingly?
  #50
Old 07-24-2014, 07:29 PM
cheezit's Avatar
cheezit
cheezit is offline
Thats correct.
The ipr is a metered oil leak back to the oil pan, any unused high pressure is dumped back to the pan.
The icp is just confirming what the ipr is doing
  #51
Old 07-25-2014, 01:19 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Originally Posted by 04badford
It must of been a looong day, from the notes the 0.2v that I was referring to was KOEO not start, so when you start Juicing the sensor at cranking .85+ BAM you get Diesel start. We need a kick my self in the Nads Icon
I thought we has enough of them being kicked in that other thread.
Sean
  #52
Old 07-27-2014, 06:31 AM
Bear 1's Avatar
Bear 1
Bear 1 is offline
Thanks for the post.
KingBigJoe
Indiana Chapter
24
02-01-2014 10:29 AM
jredline1984
Montana Chapter
486
12-31-2013 10:18 PM
archtaan
Virginia Chapter
3238
06-30-2012 08:01 PM
richhrub
6.4L Power Stroke Diesel
05-07-2008 10:22 AM
wgouldin
11-28-2006 08:51 PM
Quick Reply: Early ICP in a late year model engine: Any benefits??
