Saving money for BPD oil cooler
#31
Could be, all I know is I bought my truck with 75k on it, and the oil cooler was just replaced, I was experiencing 37 degree deltas within 10-15k miles, and I decided to go with the BPD system. Not every truck may have problems with temp spreads, but I agreed with the notion that the oil cooler was a flawed design, asking way too much from the cooling system and putting in the BPD would put less demand on the cooling system.
#32
#33
Or do what I do and turn the A/C to max, which seems to increase the fan speed at idle and cools the truck very fast, not to mention the passenger.
#34
You mention they alter the fan through tuning. There is nothing on their website that details any of this having to be done. There could be an issue with a hot day stuck in traffic BUT....on any given HOT day the ambient temp is 100*F. in bumper to bumper traffic, THEIR IS NO LOAD on the engine....temps drop drastically and oil temps normally circulating in 190*+++ heat exchanger temps are now subject to AMBIENT 100* temps....I do not understand your point if you had one.
I understand it is an air to oil cooler. The FAN moves air even at idle so if the ambient temps are lets say 100*F it is still much cooler than a heat soaked oil/water heat exchanger exposed to 200*F temps.....I don't understand your statement.
#35
I never thought it was possible to interface with the fan assy through a switch. Maybe I don't come around as often as I need to!
Any write ups on it?
Thanks
Joe
#36
#37
#38
#39
You know I was wondering if the evacuation of the system was even necessary. It appears that once all the front is removed there is a lot of room to avoid doing so.
#40
Pics or it didn't happen. Lol, I tried to see how you could have done it and I just evacuated it and paid ford dealer to recharge it. Do you know of the several flavors that they offer now which you have?
#41
I don't have any pic's left as I lost them with my last computer. All I did was unbolt and roll the condensor towards the passenger side with a bungee holding it to the hood.
#44
#45
Thanks for the help
Joe
