Transmission not going into gear at all
Old 07-24-2014, 10:02 PM
JakeMac's Avatar
JakeMac
JakeMac is offline
I put a 95 e4od 4x4 in a 97 7.3 f350 would there be any other reason that it wont shift at all other then that the pump is broke. It has 16 qt's of fluid in it so its not low. Mabey the connections, everything seems to be hooked up ok. If its the pump how much would it be to fix if i bring the tranny in?
Old 07-24-2014, 11:21 PM
madpogue's Avatar
madpogue
madpogue is offline
Have you confirmed that it's not the transfer case?
Old 07-24-2014, 11:26 PM
JakeMac's Avatar
JakeMac
JakeMac is offline
its in 2 high if thats what you mean and it worked last time i used it.
Old 07-24-2014, 11:41 PM
madpogue's Avatar
madpogue
madpogue is offline
So did the transmission. Either one is equally likely to be at fault. Simple test - shift to Park and attempt to push the truck. If it rolls, t-case is no longer engaging. If the Park pin holds, should mean t-case is okay, and indeed your problem is the tranny.
Is the OD-Off light on or blinking?
Old 07-24-2014, 11:57 PM
JakeMac's Avatar
JakeMac
JakeMac is offline
The OD light works like it should, ill have to try this tommarow, so ur saying that the connections wont have anything to do with the tranny not working?
Old 07-25-2014, 12:07 AM
madpogue's Avatar
madpogue
madpogue is offline
Sure, any bad connection from the PCM to the tranny will cause a shifting issue. Usu. a shifting issue that the PCM detects sets a code, however, and you'd expect to see the OD-OFF light blinking.
Old 07-25-2014, 09:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
A working transmission will shift into gear in both forward and reverse with or without the electrical connections. You can leave all the plugs unplugged and the trans will still move the truck.
Is there a filter inside the pan? You can see if the pump is working by putting a pressure gauge in the test port on the driver's side of the trans, near the front, just above the pan. It has a black hex head pipe plug from the factory. The thread is 1/8" NPT.
Old 07-25-2014, 01:06 PM
JakeMac's Avatar
JakeMac
JakeMac is offline
Hah seen this before i took the rear cooler line off while the truck ran and nothing came out so its a pump problem.
Old 07-25-2014, 01:07 PM
JakeMac's Avatar
JakeMac
JakeMac is offline
The park pin holds so i asume its the tranny pump.
Old 07-25-2014, 02:13 PM
Mark Kovalsky
Yes, it's the pump. No flow = dead pump.
FordOwnerJoey
03-14-2013 08:05 PM
97FRD1TN
05-10-2011 09:56 AM
mklemin
05-04-2008 09:52 PM
Carbak
01-19-2006 04:38 PM
Grogtronics
1978 - 1996 Big Bronco
07-25-2005 09:44 AM
Quick Reply: Transmission not going into gear at all
