Fuel Pressure Question
Old 07-19-2014, 01:38 PM
Traildust's Avatar
Traildust
Traildust is offline
Over the last month or so my fuel pressure went from 65 psi down to 53 psi and I have done everything I know and it still remains at 53 psi. I checked the FPR, replaced the poppet, replaced the gold spring with the black one which is suppose to produce 67 to 70 psi. With no luck at the regulator I dropped the tank looking for any obstructions and found none, screens were clean. My last try was replacing the fuel pump with a new Bosch OEM pump. Now my fuel pressure is still at 53 and under hard acceleration it will drop to 45 psi. I would like to see 65 psi again but I am out of ideas. Anyone have any ideas to help me out?
Bill
Old 07-19-2014, 02:45 PM
jasonc76's Avatar
jasonc76
jasonc76 is offline
Check the filter?
Old 07-19-2014, 04:34 PM
Traildust's Avatar
Traildust
New filter but - now that I think of it, when I replaced the fuel filter is when this started.
Bill
Old 07-19-2014, 08:16 PM
dn29626's Avatar
dn29626
dn29626 is offline
I like Purolators. What did you install?
Old 07-21-2014, 12:29 AM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
Fuel filter problems are probably a common cause of power loss in these trucks. Not all are the same quality!
Old 07-21-2014, 05:59 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Stick with Motorcraft or the Motorcraft manufacturer (racor?.. Someone check me). There is a lot of deviation from the OEM standard in the aftermarket. For example the WIX filter has a micron rating HALF that of the OEM spec at best.
Old 07-21-2014, 03:26 PM
Traildust's Avatar
Traildust
I have always used Racor or OEM. The drop in fuel pressure wasn't caused by the fuel filter I just replaced but by something in the FPR as near as I can tell. I have a bunch of parts for the FPR and ended up mixing the Billet Housing with the black spring with a .075 shim added. That put my fuel pressure at 69 psi. I am sticking with this until I find out what caused it to drop and why I have to put so much spring pressure on it to get to 69?
Bill
Old 07-21-2014, 09:36 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Where are you reading fuel pressure from? The bowl or from a regulated return?
Old 07-22-2014, 03:26 PM
Traildust's Avatar
Traildust
Off the bowl pre filter. I would go with a regulated return but I am really thinking of getting rid of this truck it's starting to show it's age.
Bill
Old 07-22-2014, 04:19 PM
white Buffalo
Well, here is my guess......
It all started after you replaced the fuel filter. If it's not the filter then it might be that the filter & cap is not pushing the spring & valve down enough in the Fuel Filter Check Valve Assembly (center of fuel bowl). If the valve is not fully open (you can see the valve has the window closed in the lower pic - the top part of the stem) it will restrict fuel flow. In the top pic you can see the window is open, allowing fuel to pass. This little gizmo is the manufacturers way of ensuring that you use a filter - no filter = no fuel flow. Since the fuel filter change was when the problem happened I would look here first. Just my opinion....
There are some pics of the Fuel Filter Check Valve Assembly on guzzles website (right before & after the reassembly: headline), and you can order anything you need from him as well. Here is the link:
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Old 07-22-2014, 05:15 PM
Traildust's Avatar
Traildust
Funny you should mention this because back in JuneI had a question about this very thing. https://www.ford-trucks.com/forums/1...eck-valve.html Maybe that spring needs to be looked at.
Bill
Old 07-22-2014, 08:30 PM
white Buffalo
I gutted the fuel valve assembly on one of our vehicles. I don't know if it was the cause or one of the fittings in the head - but my fuel press gauge used to bounce around a bit.
Old 07-25-2014, 08:20 AM
kirkharrod's Avatar
kirkharrod
kirkharrod is offline
Aftermarket fuel pressure gauges are not very accurate. A high quality mechanic's oil pressure gauge may give you a truer reading. The pressure senders go bad on the aftermarket gauges.
jhobbs26
01-08-2024 12:59 PM
BobbyB
11-26-2014 08:14 AM
teamlx88
1997-2006 Expedition & Navigator
05-24-2014 02:41 PM
baredog26
01-12-2013 06:52 AM
okaw
10-12-2006 11:11 AM
Quick Reply: Fuel Pressure Question
