Fuel pressure question
Old May 24, 2014 | 10:52 AM
teamlx88's Avatar
teamlx88
Need a quick reference on the proper working fuel pressure on my 98 Expy 5.4 right now with koeo it only primes to 10 psi. Running pressure was 20 psi and after I revved it a few times it slowly rose to 25 psi. The fuel pressure was steady and didn't rise or fall with rpm
Old May 24, 2014 | 11:39 AM
alloro's Avatar
alloro
33-35 psi
Did you try it with the vacuum hose off the regulator? It's on the tail end of the fuel rail, passenger side.
Old May 24, 2014 | 11:42 AM
teamlx88's Avatar
teamlx88
Not yet. Gonna change the filter and check again. Truck has 125k on it and the filter was changed a few years ago. How long does the fuel pump usually last on these trucks?
Old May 24, 2014 | 11:48 AM
alloro's Avatar
alloro
I have 160K on my Navigator and the original pump is still in it. For all I know so is the original filter.
Old May 24, 2014 | 11:54 AM
teamlx88's Avatar
teamlx88
I'm thinking the filter is clogged as the pressure doesn't rise or fall with rpm. But I'm gonna find out in about 30 min
Old May 24, 2014 | 01:16 PM
teamlx88's Avatar
teamlx88
Ok. The filter was a definite problem. Swapped it out and the truck has 30 psi at idle with vacuum and the pressure moves with rpm.
I guess this was Devine intervention though as I just saw that the support frame above the tank has rotted through and the rear tank support is no longer holding the tank up. Guess I'm really screwed here
Old May 24, 2014 | 02:41 PM
alloro's Avatar
alloro
Better stick to 1/2 a tank max. to keep the weight down, until you get some extra support under it.
TROPHYMAN
1997 - 2003 F150
Dec 3, 2015 10:41 AM
Traildust
Jul 25, 2014 08:20 AM
firemediceric
27
Dec 12, 2009 01:46 PM
Dogs-in-the-back
Jan 13, 2007 12:47 PM
okaw
Oct 12, 2006 11:11 AM
