1988 F350 intermittent ignition trouble
Im working on a 88 F350. The truck starts fine cold. After it starts up the first time and is driven, it won't start back up until it cools off or sits about 30 minutes. It has 40psi of fuel pressure and all the ignition components have been replaced including a new distributor. Have any ideas??
I just had a similar problem and finally traced it (I hope) to the fact that the ignition switch was too far back on the column. You can rule this in or out by seeing if the radio comes on in the rear (ACC) position. If it does, it's something else. If it doesn't, adjust the switch and see if it helps.
No codes! It just loses spark and then after it sits for about 30 minutes and then it starts right back up. And it'll run all day as long as I don't shut it off
Next time it has no spark unplug the SPOUT and see if spark returns. If not then unplug the PCM Computer and then see if you have spark.
If still no spark and no codes in CM you either have a bad ICM or Ignition coil or no power to the Ignition coil.
Check for power at the Ignition coil with a test light and the key on or cranking. It should light at both wires going into the Ignition Coil (flashing on one if cranking).
If no power at the Ignition coil then look at the Ignition switch.
Please define "No codes". If the KOEO tests pass then you get System Pass code 11. The same if there are no stored codes in CM. If you get no codes that could mean you have a bad computer (PCM) or a bad connection at the diagnostic port.
