1988 F350 intermittent ignition trouble
Im working on a 88 F350. The truck starts fine cold. After it starts up the first time and is driven, it won't start back up until it cools off or sits about 30 minutes. It has 40psi of fuel pressure and all the ignition components have been replaced including a new distributor. Have any ideas??
When it stops running have you determined if the fuel pressure drops out or is it losing spark?
Was the "new" distributor really new or rebuilt? |
The fuel pressure is good. Its loosing spark intermittently
Its a reman distributor but it did the same thing before it was replaced
I just had a similar problem and finally traced it (I hope) to the fact that the ignition switch was too far back on the column. You can rule this in or out by seeing if the radio comes on in the rear (ACC) position. If it does, it's something else. If it doesn't, adjust the switch and see if it helps.
Originally Posted by Phil Woolfson
(Post 14516785)
Most reman distributors are bad and do that. If you can get a good one without replacing it four times you are doing good.
Or you can just replace the PIP sensor that is mounted on the stator inside the distributor. What code are you getting in CM? PIP sensor? |
Originally Posted by subford
(Post 14517121)
Next time it has no spark unplug the SPOUT and see if spark returns. If not then unplug the PCM Computer and then see if you have spark.
If still no spark and no codes in CM you either have a bad ICM or Ignition coil or no power to the Ignition coil. Check for power at the Ignition coil with a test light and the key on or cranking. It should light at both wires going into the Ignition Coil (flashing on one if cranking). If no power at the Ignition coil then look at the Ignition switch. |
Originally Posted by Brandon Humphries
(Post 14518721)
No codes! It just loses spark and then after it sits for about 30 minutes and then it starts right back up. And it'll run all day as long as I don't shut it off |
I've already done all that. I installed a new ignition switch too. It could be I need to adjust the ignition switch again.
System pass everytime
(Post 14518854)
You're welcome
I still haven't found a solution!
