HELP!!!
Old 07-16-2014, 10:51 PM
mikeycars's Avatar
mikeycars
mikeycars is offline
Unhappy HELP!!!
My 03 6.0 started studdering and lost power going down the road, then died and won't start back. I was told more than likely the irp valve. I bought a socket, pulled the valve to check the screen and there was no screen on it. Ran a magnet in the hole, nothing. No trash, no nothing, no screen. I thought all irp valves had screens. Any ideas????
Old 07-16-2014, 10:56 PM
78fordman's Avatar
78fordman
78fordman is offline
Yes but it does come off. I would get a mirror and get a good look inside the hpop where the ipr mounts and make sure it's not lodged inside. What was your icp while cranking?
Sent from my leash using IB AutoGroup
Old 07-17-2014, 12:27 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Is that screen stainless steel? If it is then the magnet won't
pick it up. having a look back into the hole is a good idea.
Sean
Old 07-17-2014, 08:44 AM
mikeycars's Avatar
mikeycars
I don't know, don't have a scan gauge or any way of testing. I do have an extendable mirror though, and will try it today. thanks!
Old 07-17-2014, 08:49 AM
mikeycars's Avatar
mikeycars
Sean
Thanks man, putting a mirror in there today!
Old 07-17-2014, 04:11 PM
mikeycars's Avatar
mikeycars
Put a mirror in there and still didn't see anything in the hole. Found a piece of the fiber screen housing down in the valley, so decided to tear it down for a better look. May need a new hpop.
Old 07-17-2014, 07:16 PM
78fordman's Avatar
78fordman
I would but the torque app or scangauge before you start throwing parts at it. If the nylon screen took a crap and then got run through the hpop it could have gotten a small piece of it stuck in the ipr. Take the ipr and press the plunger in by taking a small punch and pressing in from the end. While holding it open flush with some brake cleaner. When you are done you will hear a little bit of air leak through the valve with shop applied through the same end you put the punch in. Then buy a new ipr screen kit and a new hpop screen and put it back together. You need some diagnostic reader to see what is going on.
Old 07-18-2014, 07:51 AM
mikeycars's Avatar
mikeycars
That's what I'll do, get it back together and buy a scangauge. Thanks man!!!
Old 07-24-2014, 07:22 PM
mikeycars's Avatar
mikeycars
Scanner
Will a CAN OBD11 scanner work on this truck, will it show you values or just codes?
Old 07-24-2014, 08:14 PM
04badford's Avatar
04badford
04badford is offline
If it will enter the ford Xgauges then yes not all can OBDII readers will work on our trucks , like Actron. they wont even pull DTCs
Old 07-24-2014, 10:39 PM
mikeycars's Avatar
mikeycars
Guess I'll break down and buy a scangauge11!! Thanks for all the info!!!!
Old 07-24-2014, 11:05 PM
04badford's Avatar
04badford
Scan Gauges are good when your ready to load the X gauges there's a big list to be seen on FTE, remember there's no sensor for the Fuel pressure, you will have to hook up a gauge for that , some where on here was a code to get the gauge cheaper ,I'll dig around to see if I can find it
Old 07-24-2014, 11:35 PM
mikeycars's Avatar
mikeycars
Awesome, thanks!!
Old 07-25-2014, 12:03 AM
04badford's Avatar
04badford
Old 07-25-2014, 12:08 AM
04badford's Avatar
04badford
Robot Check Robot Check
Don't know if the Edge price is good but the function is great.
Quick Reply: HELP!!!
