Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1967 F500 Questions
Old 02-10-2016, 10:40 AM
F600Logger's Avatar
F600Logger
F600Logger is offline
1967 F500 Questions
As you know I've had endless problems with the 68'. I have recently found a 67' F500 that runs and drives for 800$ . The guy has no idea what engine it is. He says it has a sticker that says "360-390"on the valve cover . It is a 4 speed, single speed rear diff. Just fill me in on what to look at before buying. What I need to know, and just general info.
Old 02-10-2016, 05:06 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Well, the basics of tires, brakes, general condition. Also, what is the GVWR and is it enough to do what you want?
If the engine is a 360/390 it was transplanted. The F500 most likely would have had a FT 330 in it. If it was a medium duty 330, the front cover would swap to an FE easily, and you'd be up on power a bit, but the FT will take a lot more abuse than an FE in a truck like that.
A 4 speed and single speed axle will limit you to maybe 60 mph. Heavily loaded you will struggle to pull hills due to the gaps between gears.
But overall, condition, how it runs, stops, turns, idles etc would be what to look for. The F500, like the F600, was a well made truck. How time and prior owners have treated it are the greater concerns here imo.
Good luck with it.
Macdave06
12-06-2008 07:02 PM
sampatton
04-07-2007 08:54 AM
di82131
Engine Swaps
02-26-2005 08:38 AM
12340987
04-11-2004 03:54 PM
garypope
02-25-2001 01:31 PM
Quick Reply: 1967 F500 Questions
