1978 F100 steering gear replacement center.
So, my power steering is loose, very loose. So instead of messing with it I decided to bite the bullet and go with a Red-Head steering box. It should arrive today. I am reading the Haynes book and it tells me to center the wheels to assure I pull the pitman arm off in the center position of the steering gear. I understand that.
The question I have is how do I know the Red-Head box center position?
Am I overthinking this?
I hope I've explained myself clear enough.
Very glad I bought a Red-Head. My truck drives so much better now, not weaving all over the road with the loose steering. Plus no more leaks!
I do suggest using a pitman arm puller to get the pitman arm off. If you don't have one O'riellys has a rental pitman arm puller, same thing with the nut that holds the pitman arm on. They have a 34 MM Axle Nut Socket that works to get the nut off if you don't have a socket to fit it. Makes it alot easier and quicker to use the pitman arm puller.
Ford p/s bleeding instructions:
1- Hook everything up
2- Fill with fluid
3- Jack up front of truck off of ground (Both front wheels)
4- Disconnect or Disable coil (So Truck CANNOT start)
5- Turn Steering wheel lock to lock about 5 to 10 times
6- Top off Fluid
7- Repeat Step 5
8- Repeat Step 6
9- Crank engine over (Ignition Disabled) and turn steering lock to lock 5 to 10 times
10- Repeat Step 6
11- Repeat Step 9
12- Repeat Step 6
13- Enable Ignition
14- Start Truck and turn Lock to Lock 5-10 times
15- Turn off Truck
16- Repeat Step 6
17- Repeat Step 14
18- Repeat Step 15
19- Repeat Step 6
20- Let Truck Down off of Jacks or jack Stands
21- Repeat Step 14
22- Steering should work just fine, have all the air bled out and have a quiet pump to boot!!!
2- Fill with fluid
6- Top off Fluid
7- Repeat Step 5
8- Repeat Step 6
10- Repeat Step 6
11- Repeat Step 9
12- Repeat Step 6
13- Enable Ignition
15- Turn off Truck
16- Repeat Step 6
17- Repeat Step 14
18- Repeat Step 15
19- Repeat Step 6
21- Repeat Step 14
2- Fill with fluid
6- Top off Fluid
7- Repeat Step 5
8- Repeat Step 6
10- Repeat Step 6
11- Repeat Step 9
12- Repeat Step 6
13- Enable Ignition
15- Turn off Truck
16- Repeat Step 6
17- Repeat Step 14
18- Repeat Step 15
19- Repeat Step 6
21- Repeat Step 14
2- Fill with fluid
6- Top off Fluid
7- Repeat Step 5
8- Repeat Step 6
10- Repeat Step 6
11- Repeat Step 9
12- Repeat Step 6
13- Enable Ignition
15- Turn off Truck
16- Repeat Step 6
17- Repeat Step 14
18- Repeat Step 15
19- Repeat Step 6
21- Repeat Step 14
qmcdugan
07-18-2016 08:04 AM
RONEV
02-22-2006 12:30 AM
jak1212
11-27-2001 03:47 PM
