07 Ford Triton 5.4 Spark plugs
Old 07-15-2014, 08:42 AM
Bearkiller's Avatar
Bearkiller
Bearkiller is offline
I am in the process of changing the plugs in my 07 FX4 5.4 Triton engine and was checking the threads in head. I have noticed some carbon build up where the electrode inserts into the head. I have thought about spraying some carb cleaner and getting all I can out but concerned about that stuff getting into the head. Any thoughts or should I just put plugs in and go?
Old 07-15-2014, 08:59 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
There shouldn't be any issues with the carb cleaner if it leaks into the combustion chamber---its pretty much designed to burn during combustion anyway.
It would be wise to disconnect the injector for the affected cylinders, remove the fuel pump relay and crank the engine a few times to clear any of it out---plug out of course.
While many here disagree with using anti-seize its great to prevent carbon build up on the lower portion of the plug, between the threads and the electrode tip.
Use of the newer one-piece plugs is also highly advisable---seems to prevent or greatly reduce incidents having to remove broken plugs in the 3V engines.
HTH
Old 07-15-2014, 09:09 AM
Bearkiller's Avatar
Bearkiller
Sounds good. Thanks!
Old 09-02-2014, 07:50 PM
PepperFX4's Avatar
PepperFX4
PepperFX4 is offline
Bearkiller- research this forum and u-tube about swapping plugs. There is a good chance one will break on you as you try to remove. Lot of advice and even an 11 page TSB on this out in the info world.
Old 09-03-2014, 06:27 AM
JWA's Avatar
JWA
JWA is offline
Good idea---here's a YouTube video that seems to have been helpful:
Old 09-03-2014, 01:35 PM
Bearkiller's Avatar
Bearkiller
Ford Triton Plugs
I successfullly changed all plugs without an incident but took my time. I am fortunate that I had another vehicle to drive while removing plugs.
Only plugs with significant amount of carbon was #3 & #4. All the advice I received was valuable but I went a step further and took a pistol cleaning rod w/ swab (make sure it's pistol rod with handle so not dropped in cyl) with carb cleaner and wiped out all of the heads where the plug entered the cylinder. I then took a piece of 1/4 poly flow tubing and duct taped it to my shop vac to insert into cylinders. I took the same tubing and blew any excess out of plug well. Sounds like a lot of trouble and was but best to do it right the first time.
An inexpensive boroscope helped so I could verify that all of the carbon was removed.
Thanks for all the advice!
elkhunter0452
1999 to 2016 Super Duty
08-12-2018 12:36 AM
Bobbys Big Red Rig
2004 - 2008 F150
19
09-05-2017 08:09 PM
Don250gas
Modular V8 (4.6L, 5.4L)
08-07-2011 12:28 AM
Wayne64
2009 - 2014 F150
02-23-2010 09:30 PM
bradplock
1997-2006 Expedition & Navigator
07-12-2008 09:58 AM
Quick Reply: 07 Ford Triton 5.4 Spark plugs
