Expy that dogs out at all different speeds.
1997 Expy EB with the 5.4. It has don't this for a while but here recently it has been really bad. You can start from a stop and say you get to 30 and then for some reason you need to pass or get out of the way. You accelerate but it never downshifts. It will ride whatever gear it's in intil it finally reaches what you were asking for. Very frustrating and almost a danger for my wife. If she needed to push it for whatever reason it wouldn't do anything except bog down. It does it at highway soled too. I time you go to pass and it takes off like a bat out of ****. The next time you try and pass it just sits there. Doesn't downshift it just slowly gains speed. It almost acts like it has a miss when you try to make it downshift. I hope I have explained it well enough.
Any suggestions would be great. I replaced the fuel filter probably 30,000 miles ago but never noticed a change when I did it the first time. Also has a fresh oil change on it.
No codes, on the highway the shifting to 2 does make it downshift but it seems to be a bit sluggish doing that. Shifting off the overdrive also does make it down shift. I checked the fluid a couple days ago and it was full. I am kinda lost really. Could it be possible that the throttle cable is stretched or something along those lines?
I'm not a mechanic, but I've torn enough stuff up to think it may be the tranny. I had an overdrive in a Crown Vic patrol unit start doing that and it was an issue with the internals in the transmission.
Something just occurred to me, and it may just be too simple....is the parking break on when this happens? I know I got in mine the other day after my wife drove it. She always sets the brake when parking. Always. It's not a problem if the E-Brake light is working on the dash. Mine doesn't. Released the brake and it was fine.
I'll be interested to know what the answer is....
98FordTruck
1997 - 2003 F150
13
10-13-2009 06:57 PM
tazo
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-21-2008 10:15 PM
mlbonfanti
1983 - 2012 Ranger & B-Series
05-31-2006 11:42 PM
