Headlight Issue
Yep the multifunction switch on the steering column was what was wrong with mine. My headlight would only work by "flashing" the high beams. There is a connector on for it on top of the steering column that was loose. Just remove the plastic shroud around the steering column and you'll find it.
Intimnasc
08-10-2012 03:14 PM
