i had to replace center support snap ring and some friction plates when put tranny back together have no od even when i switch it off on shifter no change drive just barely goes and engine reves way hi
How is 1st and 2nd? Did you reseal all of the drums and use seal protectors? Did you replace the direct clutch sealing rings? Did you torque the valve body bolts and make sure the EPC is installed correctly? Did you flush the torque converter and cooler?
