battery locations
Old 08-24-2014, 12:41 AM
oscajo's Avatar
oscajo
oscajo is offline
battery locations
Where is a good and practical location for a battery on a 52 F1. Exhaust messes up stock location. Will it fit above future AC hoses or is behind seats a better spot? Maybe under bed
Old 08-24-2014, 10:52 PM
fbb1951's Avatar
fbb1951
fbb1951 is offline
What motor are you using? Stock Flathead or something else? I put a GM HT383 in my '51 F1, and still used the stock battery location. I used rams horn exhaust manifolds. The Toyota PS unit was more of a problem than the battery holder.
Old 08-24-2014, 11:53 PM
oscajo's Avatar
oscajo
oscajo is offline
4.3 V6 manifold hits stock location. Might try the top of the firewall. Would love to see some pictures of other locations used
Old 08-25-2014, 08:42 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Higher on the firewall worked for another member here:
Ford Truck Enthusiasts Forums - View Single Post - 51 Project Build Update
Old 08-25-2014, 12:02 PM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
55- Ford Panel--- Putting my battery on outside of frame just behind passenger side running board bracket. Approx 24 inches further back and outside of frame.
Old 08-25-2014, 12:15 PM
AXracer's Avatar
AXracer
AXracer is offline
Optima makes a very compact 6V battery that can be mounted in any position, even upside down. If you are running 12V you can wire 2 in series. Could be mounted side by side behind or under the seat, laying down under the running board or under the bed, or one behind each headlight panel.
Homerunking2394
6.2L V8
02-13-2018 08:56 AM
blsd49
02-28-2014 09:47 AM
aldrowsboy
12-01-2013 11:33 PM
Redgranite_Yooper
08-25-2013 08:44 PM
ksmith203
03-01-2007 10:32 AM
Quick Reply: battery locations
