Advice please
Advice please
I am considering trading my current vehicle in for a 2000 Eddie Bauer Expedition, with a 5.4L, and am kind of unfamiliar with the Expeditions myself. What are some things that I need to be aware such as common problems, things to look over real good, etc.... before making a purchase of one. This would be purchased as a family/tow vehicle. Options are as listed below. Current mileage 124,250. Thank you in advance for any information/advice!
<table style="border: 1px solid black;" cellSpacing="0" cellPadding="2"><tbody><tr><td style="vertical-align: top;"><table><tbody><tr><td class="small">● 17 Inch Wheels</td></tr><tr><td class="small">● Abs - 4-Wheel</td></tr><tr><td class="small">● Adjustable Pedals - Power</td></tr><tr><td class="small">● Axle Ratio - 3.55</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Bumper Color - Chrome</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Captain Chairs (2)</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Cassette</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Cd Changer</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Center Console</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Cruise Control</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Exterior Entry Lights</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Exterior Mirrors - Heated</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Exterior Mirrors - Integrated Turn Signals</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Exterior Mirrors - Power</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Front Air Conditioning</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Front Air Conditioning - Automatic Climate Control</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Front Airbags - Dual</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Front Fog Lights</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Front Wipers - Intermittent</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Headlights - Auto On/Off</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Inside Rearview Mirror - Auto-Dimming</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Multi-Function Remote - Keyless Entry</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Overhead Console</td></tr></tbody></table></td><td style="vertical-align: top;"><table><tbody><tr><td class="small">● Power</td></tr><tr><td class="small">● Power Adjustments</td></tr><tr><td class="small">● Power Door Locks</td></tr><tr><td class="small">● Power Steering</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Power Windows</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Premium Brand - Mach</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Privacy Glass</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Radio - Am/Fm</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Rear Air Conditioning</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Rear Defogger</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Rear Heat - Vents</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Rear Wiper</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Rim Type - Chrome</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Roof Rack</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Running Boards</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Steering Wheel - Tilt-Adjustable</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Steering Wheel Trim - Leather</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Tachometer</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Third Seat</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Tinted</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Trip Computer</td></tr><tr style="display: table-row;" class="hidden"><td class="small">● Upholstery - Leather</td></tr></tbody></table></td></tr></tbody></table>
early model expys had heater core and air transfer issue for the air conditioning removal of the dash is required in order to properly fix this issue. commonly the four wheel drive actuator motor fails and at least on most of the ones i have worked on brake rotor replacement can be interesting all and all not to bad when taken car of their are a countless number with 200 plus thousand miles just find a good one. and brake lines are a major issue junk metal. what type of 5.4 by the way.
Take a code reader with you, ask the seller if he doesn't mind you plugging in. Check and verify all the door locks work as the acuators may need attention (there is a fix on this site), windows go up and down, cruise control works, odometer and overhead console stays lit (there is a fix on this site for that too), shifts fine, noise at start up, noise when warm. The plastic intakes are crap so check for leaks around the intake gaskets, use a flashlight and check for liquid under the intake on top of the motor. Obviously check all fluids and levels.
Hope it works out for you!
the spark plugs on these year engine are not a problem just 02 and up you run into trouble. i have seen 230,000 miles or more on a 98 5.4 along with both exhaust manifolds all brake lines rotors replaced . other than maintenance and tune up these engines had trouble with oil pan and dipstick design but it was corrected. that one thing these engine will not take is oil starvation they will blow faster than you can think if they have been run low on oil.
Make sure the rear window wiper works. Known to get gunked up and quit working. Check the radiator core supports. Check operation of E-brake. Check the coolant reservoir for obviously new coolant and/or an oily sheen if it's contaminated looking. Inspect trailing arms. Look at rear brakes and see if the axle seals are leaking.
