Max Pin Wt on 1999 F350 7.3L Diesel SRW 4x4
Old 07-05-2014, 06:19 PM
txdianimal's Avatar
txdianimal
txdianimal is offline
Does anybody know what the maximum pin weight is on a 1999 F350 7.3L Crew Cab Diesel SRW 4x4?
I am trying to calculate if this truck can tow a 11,614 lb 5th wheel. We will pull 5th wheel dry at 11,614lbs.
1999 F350 Info
GCWR 20,000
GVWR 9,900
Axle Ratio 3.73
F GAWR 5,200
R GAWR 6,000
Actual Truck Wt (loaded including full gas tank) GVW 8,460
Front Axle (xtra-loaded truck with full tank of gas-will be lighter after all stuff removed (except full tank of gas)I had items that will usually be in wifes vehicle) 5,080
Rear Axle (xtra-loaded truck with full tank of gas-will be lighter after all stuff removed (except full tank of gas)I had items that will usually be in wifes vehicle) 3,560
Tires-285
Have called dealer with VIN number....they don't keep records over 10 years old. Does anybody have one of these trucks and know what the truck maximum king pin weight rating is? I have found the other listed above from info found on web sites and other forums and some off the truck sticker. ....just cant find maximum king pin weight rating for 1999 F350 7.3L Crew Cab Diesel SRW 4x4.
5th Wheel Info-
Dry Weight 10,999
Actual Dry Weight 11,614
GVWR 14,000
Hitch Wt 2,270
Axles (2) 6,000
Tires ST 235/80R 16-E
Old 07-05-2014, 07:21 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
According to trailer life towing guide. Max towing is 13k. Nothing mentioned about pin weight. Just remember this is with a new vehicle.
Old 07-06-2014, 09:51 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
You'll have to take the truck to the scales.... weight the rear of the truck empty. Subtract that from the rear GAWR (6000). The remaining number with be the pin weight allowed. Subtract any other weight you put into the truck bed. I believe you will either need a newer (Higher GAWR) or lighter RV.
Old 07-07-2014, 07:58 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
I always recommend that you use the trailer GVW when calculating pin wt. 20% of that number is a good estimate.
But follow Buds advice and take it and the truck to the scale.
What tires are on the truck as well?
Old 07-07-2014, 08:46 AM
thomabb's Avatar
thomabb
thomabb is offline
GVWR (9,900) - truck weight (8,460) = max payload (1,440)
You are likely over weight, but you need scale data to confirm.
bowler1
2017+ Super Duty
54
02-21-2018 07:28 PM
jaherbst
2017+ Super Duty
08-15-2017 11:28 PM
f1bguy
1999 to 2016 Super Duty
03-20-2014 02:41 PM
wingcat
6.7L Power Stroke Diesel
02-15-2014 08:39 PM
bardave
General Diesel Discussion
25
02-22-2013 10:27 PM
Quick Reply: Max Pin Wt on 1999 F350 7.3L Diesel SRW 4x4
