4r100 swap to ZF6 worth it?
I would like to change my 4r100 to a zf6. I have found a guy that swapped his and his wife hates it. So he wants to swap back to the 4r100. Both trucks are 99.5 4x4 ESOF he has wiring harness pcm so I would be a complete swap. Is this a dumb idea? I have a steering column from a Manuel truck so I could do it also.
The final drive ratios are nearly the same, so there is no advantage to the sixth gear.
The fluid driven torque multiplication power of good triple disk billet torque converter might be stronger than a Southbend clutch and an aging knee.
I remember when a 7.3L powerstroke drag racer named Brian Kinney (PsychoStroker online) did the opposite swap, from a ZF6 to a built 4R100, in order to gain more advantage on his sub 12 second 1/4 miles.
