428 PI vs. Performer RPM
Old 07-03-2014, 10:50 PM
Purebeef's Avatar
Purebeef
Purebeef is offline
I have a 1973 F350 SCS, 4-speed New Process, and a 390. I want to replace the stock intake manifold, carb and add headers. I thought the Performer RPM was the way to go until I read that the 428 PI intake was better for a truck towing and running at lower RPM's. Is this correct? I'm referring to the aluminum 428 PI, not the cast one.
Old 07-04-2014, 06:52 AM
69cj's Avatar
69cj
69cj is offline
You more than likely won't be able to feel the diff. unless clocked on the 1/4 mile. Disadvantage of the stock 428 aluminum PI is that they are expensive and hard to find. Esp. if the seller realizes what he has.
Old 07-04-2014, 05:29 PM
Purebeef's Avatar
Purebeef
Purebeef is offline
That's good to know. I already have a Performer RPM. Thanks for your help.
Old 07-05-2014, 04:34 PM
KO1960's Avatar
KO1960
KO1960 is offline
Don't forget to block the exhaust crossovers at the head, since the rpm doesn't have them.
Old 07-05-2014, 06:02 PM
Purebeef's Avatar
Purebeef
Purebeef is offline
Thanks for the heads up, I didn't know that.
Old 07-05-2014, 06:58 PM
Purebeef's Avatar
Purebeef
Purebeef is offline
Any recommendations on a carb? Everything stock with the possibility of an RV cam and headers.
Old 07-07-2014, 05:09 PM
69cj's Avatar
69cj
69cj is offline
Holley 600 or 650 would be plenty. I'd advise one with electric choke. Makes life simple. I'm running a 770 street avenger on my 428cj. Idle was basically the only setting I had to adjust. It was perfect out of the box.
FEmtnmax
11-19-2005 06:29 PM
bshackelford711
06-03-2005 01:08 PM
discman
16
04-21-2005 03:27 PM
polcat
04-16-2004 07:30 AM
Jackflack
10-22-2003 10:28 AM
Quick Reply: 428 PI vs. Performer RPM
