Heated Transmission Fluid Flush
My 2010 SuperDuty has the TorqShift 5R110W trans that has the internal temp regulator that limits the external flow to the cooler until the fluid reaches ~160° so normal flush machines won't work. Ford states that you need the heated fluid flush machine in order to remove all the old fluid. I have been calling dealers in my area and no one has one of these heated trans flushers. Does anyone know of any area shops who do the heated fluid flushes?
I talked to my trans guy, he stated that the trans is at operating temp when the transfer start, so you are pulling the trans fluid out it is at operating temp. He also stated that he heats the new oil that goes back in. Maybe not the designed method, but it works.
And as Bud stated, you still have to drop the pan and change the filter.
Actually, I DON'T drop the pan...it has a drain plug. The filter is located up under the front bumper - Passenger side. Yes, there is a filter inside the tranny pan but it so coarse that it only filters out things like boulders-refrigerators etc.
Hi Charlie...how's things going?
true blue
01-15-2011 09:09 AM
