Having trouble identifying part
Old 09-10-2014, 09:59 PM
jchosler's Avatar
jchosler
jchosler is offline
I found a new oil leak on my motor coming from the driver side. It looks like it's leaking from this black part that I dont know what it is. It's right under the driver exhaust manifold, it's cylindrical looking that runs about the length of the exhaust manifold. I can take pics if this doesnt make sense. Thanks
Old 09-10-2014, 10:05 PM
fordpride's Avatar
fordpride
fordpride is offline
It's the oil cooler
Old 09-10-2014, 10:07 PM
fordpride's Avatar
fordpride
This
Old 09-11-2014, 06:12 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
You need this:
Oil Cooler Seal Kit - Riffraff Diesel Performance
It's not a fun job, and involves draining the coolant, but it is doable. There are a number of writeups here on how to do it.
Old 09-11-2014, 09:33 AM
jchosler's Avatar
jchosler
jchosler is offline
Yes thats what it looks like. thanks guys!!!
Bummer, I have the dip stick and now this to do, gonna be a messy couple of days
Old 09-11-2014, 10:29 AM
fordpride's Avatar
fordpride
Be carful with the front bolts. They go into the timing cover. Make sure the holes are clean. If oil is trapped in them you could crack the cover and that means you learn how to pull a engine.
Old 09-11-2014, 05:05 PM
jchosler's Avatar
jchosler
jchosler is offline
That would suck, I'd have to kick myself in the nuts if I do that
Old 09-13-2014, 11:29 PM
B Big's Avatar
B Big
B Big is offline
When I did my oil cooler rebuild, I did not take off the front piece. I just removed the rear oil filter housing. There is a video on you tube (a dealer tech did the video).
My truck is a 1995 2 wheel drive, if yours is 4 wheel drive you might have to take the front off.
I used Vaseline to lube the o rings and a short pry bar to push the cooler back together.
When the cooler came off the oil pressure relief valve came out and I had to re-stake it back together. On the early '95's thats the way they were built. The later ones are held together with a "c" clip.
B.
Vegas123
22
08-06-2019 12:18 PM
El Campo
1999 to 2016 Super Duty
01-16-2015 03:39 PM
44Red
06-10-2014 12:26 AM
DKelleyTX
01-02-2013 12:04 PM
Fomoko1
01-16-2008 08:59 PM
Quick Reply: Having trouble identifying part
