6.0 Rebuild
Old 06-28-2014, 07:46 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
6.0 Rebuild
I wanted to start a new thread to show the rebuild of my brothers 6.0. He is not is a hurry since his truck still running fine (just a little blowby). Block is bored .020 over and was decked .005, crank is turned .010/.010. He has an extra set of heads, if he can stay within Ford specs he will use them, if not he will be using them as cores for Ford remans. He purchased a Ford Over haul kit, so everything so far is OEM with the exception of the main and rod bearings, and they are Clevite.
He also has a set VR 20mm HGs that in the kit, we are hoping to get THAT straightened out next week.
I am pretty excited to help because I am getting to see the parts I've only heard about... For instance, I didn't know the bed plate also serves the purpose for the main bearing caps, pretty crazy...
6.0 Rebuild by Shaneb75 Picture 1536701 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536700 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536699 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536698 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536697 - Ford-Trucks
More to come.....
Old 06-28-2014, 08:04 PM
78fordman's Avatar
78fordman
78fordman is offline
At what point do you need to worry about destroked pistons?
Sent from my leash using IB AutoGroup
Old 06-28-2014, 08:18 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
That is a good question. I am interested to know as well. Between what was removed from the deck, and what will be from the heads have to stay within spec... Seems like it would be tough to do without having new heads.
Old 06-28-2014, 08:21 PM
78fordman's Avatar
78fordman
I think mahle makes .010 destroked pistons. So if they have to take .005 off of the heads it would get you right back where stock ia.
Old 06-29-2014, 04:40 AM
John Irwin's Avatar
John Irwin
John Irwin is offline
Hi Shane, I'm in the middle of a rebuild also. Word of advice... if you want to have lazy guys like me look at your pics, get them hosted on a site like photobucket and post them instead of the links.
My block is being decked... I will need to see it and talk to the machinist, but I'm not sure a 0.005 cut would cause any problems. I just measured my old head gaskets, and came up with a 0.059 gasket thickness. Assuming a zero piston deck height(IIRC) you shouldn't need to shave the pistons. All of this is theory, I don't have the block here.
Did the Ford overhaul kit include lifters, and what was the price?
Old 06-29-2014, 05:13 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
IIRC the pistons come out of the bore ~ .032.
Old 06-29-2014, 08:05 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
For the lazy ones....
Old 06-29-2014, 08:11 AM
ul37's Avatar
ul37
ul37 is offline
Looks good so far. Did you go with a stock cam or did ya go for a bigger one.
Old 06-29-2014, 08:18 AM
cheezit's Avatar
cheezit
cheezit is offline
Guys there is an update for doing the bed plate. Use anaerobic silicone with the worm gaskets
Old 06-29-2014, 08:19 AM
cheezit's Avatar
cheezit
cheezit is offline
Ill never understand the need to paint an engine
Old 06-29-2014, 09:27 AM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
It makes it easier to see the bed plate leak!
Old 06-29-2014, 02:01 PM
npccpartsman
If you do this then the bedplate won't leak.
Old 06-29-2014, 02:07 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
I think they call it pride Moe,but I've been wrong before
Old 06-29-2014, 02:35 PM
cheezit's Avatar
cheezit
cheezit is offline
Comming from the dealerships we stoped painting engines years ago, it was a cost reduction movement. They saved on warranty oil leaks and paint.
Old 06-29-2014, 03:49 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Thanks, He stayed with the stock cam.
Quick Reply: 6.0 Rebuild
