New guy with 48 F1?
Old 06-28-2014, 06:38 PM
66f100tx's Avatar
66f100tx
66f100tx is offline
New guy with 48 F1?
Hey everyone. Wanted to take a moment to introduce myself. I'm Andrew from Dallas Tx. Been lurky on the site for awhile and just bought a new to me 48 F1 or so I think. I was wondering if someone could help my with the numbers I have. On the title I received it lists the serial number as 71FM110062 8RT500 and on the firewall it has the following: 10CH 4A 14A Do these numbers mean anything? I know there is a hidden number stamped on the frame but I have yet to find it. Any help is appreciated. Thanks.
Old 06-28-2014, 07:35 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Welcome Andrew! The vin is on the top side of the passenger side frame rail between the radiator and block. I don't recognize the number you shared. I take it there isn't a plate on either the firewall or the glove box?
DW
Old 06-28-2014, 09:22 PM
66f100tx's Avatar
66f100tx
66f100tx is offline
Thanks for the welcome. No, the truck has been stripped of all the data plates. There are no tags on the truck of any kind. I guess I will have to find the "hidden vin". Just curious of those numbers had any meaning.
Old 06-28-2014, 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Welcome! Those look like TX-assigned replacement VIN numbers, nothing OEM. Check the frame rail if it's still there (not modified with different suspension).
Old 07-01-2014, 02:35 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Hi Andrew,
Welcome to FTE. Here is a key to the firewall/cowl stampings:
Your number (10CH 4A 14A) doesn't make a lot of sense to me but they are hard to read sometimes and if it was 1CH that would be a 1951 Chicago Plant built cab. 4 would be a spur gear 4 speed (w/granny low & no synchros) and A would mean that the truck was originally painted black. There should be a 5 digit plant sequence number after that. But I'm guessing and there are some others with more experience on here that can correct me if I'm wrong.
How about posting some pictures?
Once again, Welcome
Michael.Smith928
15
12-03-2016 01:25 PM
tinman52
05-02-2016 09:14 AM
cisco123
04-15-2009 07:01 PM
triplediver
03-14-2008 02:31 PM
chilione99
01-15-2006 10:14 AM
Quick Reply: New guy with 48 F1?
