Welcome to FTE. I moved this to the large truck section. I think that is where you can get the best help.
So what are your questions?
Looking for some Troubleshooting tips with the stock Ford A/C system. One day it works, the next it doesn't. I am going out with a meter to check the fuses and maybe the switch assembly and someone local phoned up and said it might be low pressure in the system itself which would stop the clutch from engaging. So more ideas would be great before I go out to the RV. Waiting for the rain to stop for a while.
I'd say for a F53 chassis, ford was NOT the mfg of the AC system. Ford may have shipped the chassis with a engine mounted A/C compressor but I'd bet that might be all.
It is not the two A/C motorhome units that I am referring to; it is the system mounted to the Ford V-10 engine. I understand that more info is required about engine and transmission. I will see what I can dig up on it.
