Bad wheel bearing or something else ?
I think I may have a bad front left wheel bearing. When I go around right-hand corners it seems to be that there is a vibration on the left-hand side. It only vibrates when I turn hard or on rough road surfaces.
I also just replaced the front brakes and rotors and inspected all of my wheel bearings they appeared to be good but I could be wrong!
I just put brand-new 38 inch Toyo MT tires on and I was thinking that with the more tread and I was getting road vibration !? but I had 35 inch toyo MTs before the 38 inch MTs and I did not have this sort of issue.
Also I just had heavy-duty U joints installed about a month and a half ago and was thinking that with these new U joints that could be the problem
One more thing is that I was reading with an aftermarket downpipe on the power stroke diesel sometimes it rubs against the firewall on certain left-hand and right-hand corners causing it to vibrate.
I have no idea where to start and I don't want to just throw parts at it. So if anybody has anything for me to check or look at let me know
How bad really is it? Does your truck bounce up and down badly? Don't think it's your wheel bearings since you said you just had new U joints put in. You said you inspected your wheel bearings. If they were bad you probably would have noticed. Bad U-joints usually pop and your suspension will feel like ****. don't think that's the culprit either.
Jack up front end. Pull tire.
Grab the whole assembly and shake.
Is there play?
if yes = bad ball joint,
if no = ball joints good.
You can do it with the tire on, its just harder to tell whats going on, you cannot physically see whats going on.
Is there play?
Big Daddy Braddy
1997-2006 Expedition & Navigator
02-11-2013 12:13 PM
2002f2507.3LPS
04-17-2007 02:27 PM
Powerstrokedlariat
01-23-2005 02:47 PM
