wiring a starters on a 48 f1
Okay I need help with the starting system here is what I have done I have installed all new wire harness and it is a 6 volt so my problem is that it is positive ground and I can not get the cab to ground without having a short I have ran cables from motor to frame and battery to frame and from battery to motor and I still have a problem my volt meter show the cab is 6 volt I also have installed new body mounts and motor mounts and transmission mount .. now keep In mind I can start the truck by taking a jumper wire and grounding the starter button housing . The starter button has one wire on it and it goes to the S on the solenoid if any one has seen this please let me know
Well the one I got was not exactly the same, but it does fit the hole. I think I got it at NAPA, I think they had others too.
You mean positive ground and it is . It show 6 volt and the frame and the motor also shows 6 volts .. thats the problem lt needs a ground to ground the starter button housing because it has one wire coming from the starter solenoid to starter button ( this thing is about to make me pull my hair out ) lol thank you for your help
In your first post you said the starter button wire is on the S terminal, these trucks use a solenoid with only one small terminal I'm wondering if you're using later model solenoid? engine?
For the original V8 system, looking at the solenoid as mounted on firewall the negative post on battery connects to the right large terminal on solenoid, left side terminal goes to starter. Positive post on battery connects to engine, frame etc.
One side of the coil inside the solenoid receives power (neg) from the battery post (wired internally) the circuit is completed when you push the starter button which is positive (ground).
There is some evidence that is how the factory did it, but it's wrong. The only load that needs big (#0) cables is the starter, so the battery ground cable needs to go to the engine or trans, on a substantial bolt. From there you can run a #10 to the cab and a #12 to the frame for lights and accessories.
Iam getting 6 volt at the cab by touching the cab and the negative on the battery and yes it looks like I have a short but where on a 6 volt system the positive from battery to engine and negative to starter solenoid I have replaced all new wire harness from LMC it is so simple and that's why it is kicking my butt ... thank you and everyone else who has help me this forum has the best group of people who care and go out of their way to help .
And when I removed my working starter button from the dash to rewire it, it stopped working when I put it back in the dash. I had to "clean" the hole and sides of the switch to get good contact for the ground needed to operate the starter relay.
96powerstroke
13
04-04-2009 10:27 PM
dukey
02-10-2004 07:12 PM
