E4OD Tranny grinding lost drive... HELP!
I have not.
I got her moving enough last night to get her closer to my shop, but it didn't feel "right" and I don't really want to bugger too much with it and brake something even more.
If the sprag clutch you mentioned has failed, has it likely grenaded itself, or can they just wear out??!
I know the basics of how auto trannys work, but they mystify me for the most part as I have never dug too deeply into one...
Hard to say natrually but +1, I'd check out the T case before sending it to any trans shop.
Its possible....and very likely they'd go right for trans rebuild assume its the problem without looking into it further do so and put it back in the truck only to find it suffers same condition.
Then call you with the bad news "trans is fine now but we found when the trans went it took the T case with it so you need it rebuilt too" (or words to that effect) then charge you for a t case on top of the trans hand you a huge bill for both of them sending you on your way.
Supposed to be ready today... should be expensive.
I find it odd it was in 4L when it was in 2HI when I sent it to them. Unless they bumped it pulling it out, or they tried shifting it like I did...
This appears to be EXACTLY the case. Called them yesterday to see where they were at with it. Said he went to road test it and it was stuck in 4L. They pulled the transfer case and found a "broken fork". He also said it was lucky they cracked it open because the pick up for the pump had broken off and it was only getting oil that was being sloshed around.
+1 on a good used T/C, even if split the case a minute first to correct the known retainer pump issue, would have been a whole lot cheaper than a "rebuild" (by a shop) and with the "pump fix" in place a minute would likely outlast the truck.
Well, the tranny was rebuilt in July, and now its doing the exact same thing. Was slipping in and out of drive on the way home last night (felt like It was in neutral) and made a horrible grinding when put in Park position.
Started with a "clunk" when I pulled up to stop at a light. It would catch and then shifts perfectly, but then as soon as you slow down, it down shifts it looses drive. When it does catch drive again it does so very harshly.
Any idea as to where to look? I called the tranny show and he was perplexed, said to bring it in as its under warranty.
I'm thinking not so much a tranny issue as something else. I dont wanna take it to them and end up with another huge bill and still the same issue.
What about the PCM? Could failed capacitors cause this issue? Sensors to check?!?
At the same time, after the rebuild it was perfect so why 6 months later would it rear its ugly head again.
Also; O/D on/off made no difference, and manually selecting gears did nothing. (except grind when going to park) Engine speed surges when selecting drive /reverse.
Both of those issues were corrected in July. They cracked the transfer case open to find the shift fork broken, and the oil pump non functioning... Would be very odd if the same had happened again only 6 months later
If they put in a used case then it probably did blow up. Not odd at all to me, because I bought my truck with a used t-case and when it grenaded it caused the exact same symptoms your truck has now.
#28
#29
