A/C not cold enough
A/C not cold enough
It seems as though my A/C is not blowing cold air. I have added refrigerant and check the levels. I know if one issue and that it only blows at the highest level but still it's barely cool air. Right now I'm basically driving with the windows down. Can someone point me in the right direction on what can possibly be the issue? Thanks!
What is the model year of your Explorer? Does it have R-12 or R-134a? If it is older than a 1994 model year, has it been converted for R-134a? If it's an R-134a system and overcharged it could blow warm.... How long does the compressor clutch remain engaged? Do you have a manifold gauge set so you can monitor the high and low sides at the same time while the system is on and engine running?
-Rod
-Rod
If there isn't a leak, the level should not be down anyway. If the clutch was not cycling frequently prior to adding R-134a, the level probably was not low either. If you added R-134a to an already properly charged system, then it will be overcharged which will further degrade system performance. Without monitoring the high and low pressures at the same time it's quite difficult to determine if the system has a sufficient charge.
You might have an issue of a blend door that is broken (pretty common on Explorers and recent Fords in general) blending too much heat from the heater core.
-Rod
-Rod
daymienrules
03-26-2014 12:07 PM
