Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
01 Escape With A/C Issue
Old May 17, 2008 | 05:49 AM
Slotguy's Avatar
Slotguy
Hello all. Back again with another problem. The A/C on my wifes 01 Escape (3.0 V6, Auto., 2WD) works fine when sitting at a stop, but as soon as you drive off the cold air stops flowing. When the vehicle comes back to a stop, air gets cold again. You can rev the engine when sitting still and air stays cold, but drive the darn thing and cold air stops again. Appreciate any comments or solutions, the weathers getting warm and need to keep the wife cool.
Thanks
Old May 27, 2008 | 02:14 AM
Slotguy's Avatar
Slotguy
Just to let all know for future reference, the problem was low freon........at least according to the ford dealer. A/C seems to be working fine now, will let all know if it comes back.
Thanks
Old May 27, 2008 | 06:43 AM
DoctorCAD's Avatar
DoctorCAD
Sounds about right.
Old May 27, 2008 | 07:50 AM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
When you drive you get more airflow through the condenser. This lowers A/C pressures. On a system low on refrigerant, the pressures are already low to begin with.. the extra airflow could be just enough to trip the low pressure cycling switch, thus disengaging the compressor.
I hope they injected some flourescent dye into the system for you. If it was low that means there is a leak, which means it'll probably go low again. The dye makes it so much easier to find the leak.
Old May 27, 2008 | 03:20 PM
Slotguy's Avatar
Slotguy
Didn't say if they added any dye or not, but did say they checked it for leaks - and found none. Been a couple of years since last A/C checkup??? Will keep an eye on it and see what transpires. Thanks for the explanation.
rexpedition99
20
Aug 24, 2012 12:40 PM
BigBadBob
2011 - 2019 Explorer
Jun 28, 2012 07:04 PM
race39
Mar 29, 2012 11:59 PM
mudder460
Oct 25, 2011 09:48 PM
patrickemb
Mar 27, 2006 11:43 PM
