Opinion on truck
I had a oasis run the only thing ever done under warranty was a hpop and fitting at 82000 miles. Also pulled trans and replaced rear cover at this time. Don't know what that's about. It was brought in for no or hard start when warm. The fitting I am guessing was the Stc fitting.
Ok update on history I called everyone listed in the car fax and they told me everything they repaired on it. The truck had head gaskets done on it at 206k in 2011. 5 injectors at 234k in July 2012 and 2 more in April of 2013. Then in June of 2013 at 253k the headgaskets were replaced again and I assume that's when they dis the egr delete. Not a repair shows on the car fax since then. Does all this scream RUN!
Even thou it has high mileage and has a few issues it doesn't mean run,a good deal is a good deal and if you can get it for 5-6 K,I would consider it a good deal.From what you have found out it sounds like it was taken care of,now you have to get us numbers so we can look into the hot start issue.Don't mind Monty, he's just pissed cause he made a stupid mistake and it cost him a bunch of money,so he bashes 6.0's every chance he gets
If the guy doesn't mind you running some tests on it, rig up a gauge on the degas bottle to check how much pressure the coolant system is building.
With the STC being replaced, a guess on the HPO leak would be the stand pipes/dummy plugs, or possibly the cup seals in the oil rails. I think there's a good chance it has now ran for 21k miles with the green coolant so a chemical flush and maybe even an oil cooler is in it's future. I would also point out the green coolant provides a little insight into the (lack of) 6.0 knowledge of the mechanic, making the last head gasket replacement a little suspect. Several injectors might indicate the fuel pressure is low (blue spring?) or a FICM or battery/charging issue or both. I don't know about running away-but going in with your eyes open would be wise as some of these issues can be pricy to repair. Particularly the head gaskets.
I'm not sure if your familiar with Monty (posted above^) but he provides the function of resident troll and antagonist, specializing in talking bad about 6.0's to posters who are looking to buy, and mind numbing repetition. I wouldn't put too much stock in his assessment of this truck requiring a engine replacement. As I'm sure you know, it's entirely possible the engine could go another 100k or more, or crap out next week. Just like any used vehicle.
Finally, the trend for a replacement/rebuild just based on mileage and wear seems to often be the lifters. It's not practical to tear it down to inspect them but if significant wear or failure has already happened it's possible to hear one squeak just as the engine comes to a stop on shut-down. It may not do it every time based on where -in it's rotation- the engine stops. Just one more thing to check.
Ok I haven't been able to figure out how to run the livewire to get those readings yet. I did have the ford diesel mechanic look at it and he's very confident the hard start when warm is the stand pipes.(for what it's worth) he didn't like the K & fipk or the livewire but I chalked that up to his ford mechanic back ground. I don't totally disagree on the fipk I think if I buy it I will buy a stock air cleaner setup. I was thinking I might try 6 but I don't know if I can get them to come down any more. He also sid he thinks the bed plates might be leaking.
Essentially, as was suggested earlier, it could blow head gasket next week or never, without knowing the quality of the repair or shop's experience
If the truck is awesome and you can handle a potential engine rebuild expense then maybe it's a deal.
Monitor: The ficm, fuel pressure spring kit, alternator, batteries. A complete fluid flush should be done too.
Don't skimp on maintenance or use somebody who 'thinks' they know the 6l.
Good luck.
Sent from my Sprint PC36100 using IB AutoGroup
These are the PIDs it will monitor
Ford 7.3L and 6.0L PID's
ACCEL PEDAL POSITION
AIR FLOW #/MIN
BAROMETRIC PRESSURE IN HG
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INJECTION CONTROL PRESSURE
INJECTOR PULSE WIDTH
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TORQUE CONVERTER CLUTCH DUTY CYCLE
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
FICM_MAIN_INTERNAL_INJECTOR_PWR
If it was mine, I'd keep it
AIR FLOW #/MIN
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
#28
AIR FLOW #/MIN
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
AIR FLOW #/MIN
BATTERY VOLTAGE
COMMANDED GEAR
COOLANT TEMP
ENGINE OIL TEMP F
INTAKE AIR TEMP
LOAD
TURBO BOOST
MAP
RPM
TRANS TEMP
VEHICLE SPEED
VGT DUTY CYCLE
FICM_IGNITION
FICM_LOGIC_POWER
Is the livewire a wireless unit or wired?
Sean
#29
