What is this hose?
Old 06-30-2014, 10:27 AM
rlculver's Avatar
rlculver
rlculver is offline
What is this hose?
I have a 2005 Expedition and this hose is leaking at the T. Would it have anything to do with the a/c not working? Does anyone know what the part number is?
Old 06-30-2014, 10:54 AM
David7.3's Avatar
David7.3
David7.3 is offline
Rear heater hose for the heater coes
Old 07-02-2014, 03:13 PM
1saxman's Avatar
1saxman
1saxman is offline
The compressor won't run if the refrigerant is low. There are plenty of other reasons, like a bad fuse or compressor clutch.
Old 07-02-2014, 03:36 PM
ojai150's Avatar
ojai150
ojai150 is offline
My AC stopped working once on my '04 F150 , I took it in to a trusted mechanic, turns out the bolts had come loose on the clutch , and he just bolted it back on , and 4 years later , works perfect
Old 07-04-2014, 10:41 AM
TransWorxs's Avatar
TransWorxs
TransWorxs is offline
If you have a test light/power probe check for power at the compressor. If it's not receiving power then check the low pressure switch. You might just have a leak to the point that the compressor won't kick on.
FSTBLL42
07-15-2019 01:29 PM
bulldogcountry1
03-28-2017 07:29 PM
GoldCo
02-27-2017 11:05 PM
Barryrod
1997-2006 Expedition & Navigator
08-03-2015 08:33 PM
Georgemgeorge3
09-08-2003 10:36 PM
Quick Reply: What is this hose?
