7 pin connector installation
#32
#33
Still trying to find the right relay for the Trailer Tow Battery Charge relay, not getting anywhere. Found another number from a F150 Forum also said to be used in the Expedition, does anyone have any information on the following number - FOAB-14A192-A. I also see this number with AA at the end vice A.
Apparently this number was incorrect for my Expedition - F80B-14B192-AA
#34
Decided to go to a Ford dealership to find out the correct part number. What I found is as follows - found out the number I received recently was a correct number but not the part number.
FOAB-14A192-A is the number you see on the relay but it is a engineering drawing number so when you go to a parts store and try to find a cross reference you get nothing.
The part number is FOAZ-14N089-A.
I plugged the relay in and do not have 12 VDC, I think the way I spliced the wire in to the orange wire along the drivers side frame rail could be done better. I used the quick splice item from etrailer and don't think it worked right any ideas on how to splice in with a better option?
#35
#36
kwisniski
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-20-2018 01:14 PM
chucky2
1997-2006 Expedition & Navigator
03-31-2016 08:55 PM
Caldwell F150
06-18-2014 05:21 AM
