Plz need help with a 4.6
Old 06-16-2014, 01:23 PM
Bartramk's Avatar
Bartramk
Bartramk is offline
I have a 2001 f150 it stumbles on take off and in regular drive gear. I've changed spark plugs and all coils are working fine. I'm getting a couple of codes on the scanner one is p1408 EGR flow out of range. It has a brand new EGR valve on it. Secondly it's showing p1131 h025 bank 1 sensor indicates lean. I don't know what to do no cat codes or misfire codes what does all of this mean?
Old 07-25-2014, 11:44 AM
Coondawg's Avatar
Coondawg
Coondawg is offline
Try cleaning the throttle body and maf
sensor.
Old 08-12-2014, 01:18 PM
Driver Jim's Avatar
Driver Jim
Driver Jim is offline
For the EGR:
It's vacuum modulated, so I'd look at the tubing to make sure it seals properly/nothing was broken when the valve was changed. If the vacuum reaching the EGR is wrong, the valve won't open properly.
Actually, as I re-read your post I'd most definitely look at the vacuum modulator tubing as a leak will suck in air unaccounted for by the MAP/MAF, thus leaning the air/fuel mixture. Bank 1 is the one through four cylinders on the passenger side, which is where the tubing for the EGR vacuum originates.
velcro7279
10-04-2010 09:32 PM
66fdtrucknut
1983 - 2012 Ranger & B-Series
05-28-2010 06:53 PM
BrokenSockets
1997 - 2003 F150
06-22-2006 11:37 AM
sayce
Modular V8 (4.6L, 5.4L)
19
12-07-2004 03:24 PM
brannma
08-25-2003 07:25 AM
Quick Reply: Plz need help with a 4.6
