6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Lower left coolant leak
Old 06-26-2014, 06:46 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
If anything removing the egr coolers free up a ton of room as stated by longview1, I bought mine off Ebay for like $120.00.
Downpipe should be next weekend for me.
Old 06-27-2014, 12:42 AM
longview1's Avatar
longview1
longview1 is offline
I used flo pro for delete of egr. There's other options too I'm just not sure what.
Old 07-01-2014, 10:33 PM
Laner's Avatar
Laner
Laner is offline
I assume you did just the block off plates, correct? I was thinking the full egr delete, but then got me thinking about how much boost I build pulling trailer and have heard that it would be best to have a wastegate then. The egr kit with wastegate is much more expensive. If you don't do a wastegate, then is there no place for the extra boost to go when it gets too high?
Old 07-02-2014, 10:36 PM
longview1's Avatar
longview1
No i did full delete. Youll be fine without a wastegate, unless you plan to race or add more power makers? JUst dont stomp it and let off right away 1000x a day and youll be good!
Old 07-07-2014, 08:25 PM
Laner's Avatar
Laner
Laner is offline
Originally Posted by slowmans
Do the thermostats too!
Best to use Ford thermostats or aftermarket? Not going to do EGR delete yet as mechanic doesn't have time to slip it in between other jobs. I can do that later myself.
Old 07-07-2014, 09:14 PM
slowmans's Avatar
slowmans
slowmans is offline
I'd stick with the Motorcraft, they aren't that expensive anyways
08 6.4L Spartan
11-13-2018 09:46 PM
killacal
1999 to 2016 Super Duty
05-21-2016 04:39 PM
PSDx3
06-28-2013 09:57 AM
first truck
07-29-2009 09:02 AM
77hiboyboy
12-08-2004 07:14 AM
Quick Reply: 6.4L Lower left coolant leak
