Should I drain some Trans Fluid
Old 06-15-2014, 12:20 PM
jayro88's Avatar
jayro88
jayro88 is offline
So I flushed my c6. I got rid of the slight shudder I had at times shifting into 3rd. My fluid level is in between the 2 dots (holes) when the trans is not warmed up and is slightly above the hashmark when at full operating temp (probably 3/16" above). It sits just below where the dipstick starts to twist. I know you don't want to overfill the trans. Should I drain out a little so it is right in the hashmark hot, or am I over thinking it?
Also, is there a trick to easily reading the trans dipstick? When it's cold the ATF is thick enough that it sticks in the holes and is easy to see. At operating temp it doesn't and is tough to see where it stops, especially when it's new and clean.
Old 06-15-2014, 07:50 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
I wouldn't worry about that small an amount myself.
bmuhlbach
Escape & Escape Hybrid
04-26-2015 08:12 PM
Bubba Jim
02-02-2014 10:03 PM
big daddy f350
09-28-2006 08:42 PM
883024x4
15
07-05-2006 12:34 PM
883024x4
06-19-2006 04:06 PM
Quick Reply: Should I drain some Trans Fluid
