Best clutch kit?
Old 06-14-2014, 04:00 PM
Royson12's Avatar
Royson12
Royson12 is offline
Best clutch kit?
Well, on the way back home from San Antonio, my throw out bearing came apart. Limped my truck back home. Pressure plate is trashed! Time for a clutch kit. Orielly a has a "power torque" , never heard of them. Don't really trust some of thier parts anyway. Napa has a "fueca". I think. Or should I just wait for the ford house to open Monday? Napa usually seams to have better stuff than oreilly, plus it's a $150.00 dollars more. That doesn't bother me, as long as I get what I pay for. What would you guys suggest.
Old 06-14-2014, 04:29 PM
farmert's Avatar
farmert
farmert is offline
I have used the single mass conversion from Napa for 5 trucks with no problems. But I believe they were branded Perfection if I remember right.
Old 06-14-2014, 04:55 PM
Royson12's Avatar
Royson12
Royson12 is offline
What's the difference? And the cost?
Old 06-14-2014, 05:03 PM
fordpride's Avatar
fordpride
fordpride is offline
Do you have any mods?
For stock to basic mods I like the LUK clutch with SMF
Old 06-14-2014, 05:07 PM
Royson12's Avatar
Royson12
Royson12 is offline
For stock to basic mods I like the LKQ clutch with SMF
Bone stock! Might wind up puttin a chip in it someday. Not for hotroodin, just for pullin a trailer and mileage.
Old 06-14-2014, 05:31 PM
Royson12's Avatar
Royson12
Royson12 is offline
How would I tell if my dual mass flywheel is bad? Or should I just change to single mass? I just want it to be dependable, I travel this great big state in it, a lot!
Old 06-14-2014, 05:53 PM
fordpride's Avatar
fordpride
I would put a smf. The dmf is a ticking bomb if it comes apart it will be bad. You'll be needing a new clutch and trans
Old 06-14-2014, 06:03 PM
farmert's Avatar
farmert
farmert is offline
A lot of times you will get a rattle from the flywheel area when you shut the engine off. The first one of mine that went bad would slip, even with a new clutch and pressure plate. Then we had 2 or 3 that the center bearing in the flywheel crapped out, giving a terrible shake to the tranny, which resulted in a broken bell housing on the 97, which means a different tranny. Remove the inspection cover on the bottom of the tranny so you can see the flywheel. The dual mass will have springs, like the dampner springs in a regular clutch disc, in the flywheel. Try to rotate the flywheel back and forth. If you can rotate it mor than 5/8 of an inch the DM flywheel is toast. I would go with a single mass conversion if I was putting in a new clutch. Those dual mass ones are a ticking time bomb.
Old 06-14-2014, 06:56 PM
Royson12's Avatar
Royson12
Royson12 is offline
Mine rotates about 1" or so. So I recon I'm in! Don't want to buy a tranny!
Old 06-14-2014, 06:58 PM
Royson12's Avatar
Royson12
Royson12 is offline
And the little extra noise doesn't bother me, diesels aren't known for stealth anyway! Lol. Long as it lasts!
Old 06-15-2014, 09:27 AM
Royson12's Avatar
Royson12
Royson12 is offline
Local Napa has the smf kit. Gonna go pick it up today. Thanks Guys!
Old 06-15-2014, 12:01 PM
Royson12's Avatar
Royson12
Royson12 is offline
Well my chiltons book doesn't tell me torque specs for the pressure plate bolts, or the flywheel bolts. Can anybody tell me what they are? And should I locktight them? Workin on it today, gonna try to get it together. I know its fathers day, but I have to get it done. And happy fathers day to all!
Old 06-15-2014, 06:08 PM
farmert's Avatar
farmert
farmert is offline
I can't tell you the torque specs, I just went "goodntight". Never used locktight, but used thread sealer on the flywheel to crank bolts.
Old 06-16-2014, 09:30 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
IIRC, it should be around 85 ft lbs on the flywheel and 25 ft lbs on the pressure plate and use loctite on all the flywheel and pressure plate bolts.
Torquing the flywheel bolts is not as important as the pressure plate bolts. Good and tight on the flywheel is fine. The pressure plate bolts all need to be exactly the same torque.
For future reference, my choice for a stock replacement clutch is the LUK SMF kit.
Old 06-16-2014, 11:57 PM
FI460's Avatar
FI460
FI460 is offline
I cant remember if I used the Valair clutch kit numbers or if it was something I found online, but I did 85 and 20 ft/lbs.
Quick Reply: Best clutch kit?
