Any tricks to removing crankshaft?
Had enough of trying to find a drop in engine... I talked to 3 different people with engines, none of them could even produce an engine. They have them for sale, but they're still in the truck, and they're too busy to pull them out... they're not sure if anything is wrong, I bought the truck at an auction, I bought it from a buddy...
So I'm going to fix this one, I KNOW what it has for parts in it, so there won't be any surprises when I go to fire it up. I read in run6.0run's engine removal thread that there's 6 do not **** with bolts, so I'm wondering what I need to not screw up pulling the crank out.
Back end of the crank shaft.
I don't have a photo handy. The are the ones that
hold the part that the seal rides on.
You can remove the ones that hold the flex plat in place.
Then there will be a metal dust shield. They no,no bolts
are under there.
The reason to not remove is the crank is ground and balanced
after they are installed. So you will upset that. Also don't
swap the bed plate or you going to have to have that line bored
to get all the surfaces in line and then you have to go with over
sized bearings. That is if they even make a line bore set for that.
Sean
are under there.
Sean
Could you determine where the Blowby was coming from yet John??
Anthony would be a Good guyb to talk to about it he is one of the very few I know that has don't a complete overhaul and done it correct for that matter
I think it would pay for you to PM him and get his insight for what works and what don't that way you get it done right the first time and don't have any issue
I think a Major Rule is to stay with OEM PARTS
Ok, kind of stuck... got the rear plate off, there's 6 bolts on the end of the crank, are these the six dnfw bolts? Cheezit said to pull the cam first, but I can't get the cam gear past the crank - the cam gear appears to be pressed on, and I'm assuming the cam comes out the back?!
These engines are soooooo different than a gas engine...
Crank before cam.
The cam should be the last thing to come out of the block.
Sean
